GIS Tools for Land Cover Change
4038
5
09-21-2011 05:39 AM
PaulaSalvador
Hi!
Wich tools are normally used to quantify and locate land-cover changes (in particular degradation and regeneration)?
TonyContreras
You could start here, and for more advanced analysis, you will probably need to use a combination of tools in Model builder, probably utilizing the Conditional and Map Algebra toolsets.
Using the Difference button on the Image Analysis window
TimothyHales
Esri Notable Contributor
There is also some land change imagery available on the Landsat Imagery site under the Landsat Community.
PaulaSalvador
Now I would like to know wich tools shoud I use to access the dynamics of a woodland considering that the land-cover is heterogeneous. would that be the same?
JeffreySwain
You will need to create the land cover raster. If you have a 3 band raster, you will need to perform either a supervised or unsupervised classification to create the raster.  Do this for both sets of data.  Once you create the rasters, you will need to compare the two rasters for the change analysis.  There are many examples on how to do this, including this link.  Also here is supervised classification.
Here is the information about image classification.
Also here is the information on LUCAT Tools.
So there is a process, but it will require you to process the data, not just run a tool.
PaulaSalvador
Thank you. I have done it and i really appreciate your help. Regards
