Flow Direction Cell Count
1269
03-26-2013 06:59 PM
TomGebhard
First post!  I am new to GIS, so bear with me.
I created a flow direction layer, and the layer has more cells than the input surface layer.  How can this be?  The reason this is a problem for me is that I am using the direction layer to calculate flow accumulation, and I would like to translate this to drainage area.
Thanks in advance
curtvprice
Thanks in advance
Before you calculate flow direction make sure that the environment is set up not to resample anything:
These should be default or same as your surface raster
- outputCoordinateSystem
- cellSize
Also, it's best practice to set the snapRaster to the surface raster.
TomGebhard
- cellSize
That worked.  Thanks!
