Fill Tool Error 010429
25559
11
11-04-2013 09:08 AM
MathewSchmidtlein
I'm trying to fill a DEM.  I keep getting multiple Error 010429 messages.  I can't find great documentation on this problem.  I've tried running the tool on multiple input DEMs, saved in various locations, with outputs written to multiple formats.  The messages associated with the error varies, but includes things like "Error in GRID ID: CalcPackedBytes: invalid depth: -1," and "Error in GRID IO: S_VXfer: Read error".  It is often accompanied by Error 010244: Could not set the analysis window.
I can't find any documentation on these.  Has anyone else encountered these problems, and found a solution?
curtvprice
William Deadman​ re your 'fix' -- my guess is the new ArcMap document had a nice clean raster environment that didn't have environment properties set that were breaking the tool. An example of a setting that would cause this issue would be a workspace or scratch workspace setting pointing to a workspace that did not exist.
One place to look for such settings is in the Results window entry, which includes a list of all active environment settings when the tool was run.
jamalhassan
One solution for this problem may work. when you create a mosaic from DEMs, do it in projected coordinate system. My problem solved when I created DEM in file geodatabase by selecting WGS 1984 projected coordinated system.
