Extract Values to Points error
11844
10
03-25-2011 07:00 AM
PeterMelle
I am trying to use the extraction tool in spatial analyst, specifically extract values to points. I need to extract values from an input raster from a vulnerability map to a point layer of groundwater wells, but when I perfrom the operation I get the following error message:
Executing: ExtractValuesToPoints Buda_Wells DRASTIC H:\Senior_Project\DRASTIC_MAP\DRASTIC\Well_DRASTICScores\trial1.shp NONE VALUE_ONLY
Start Time: Fri Mar 25 10:57:28 2011
ERROR 999998: Unexpected Error.
Failed to execute (ExtractValuesToPoints).
End Time: Fri Mar 25 10:57:29 2011 (Elapsed Time: 1.00 seconds)
I am unable to determine the cause as this is a general error. Any suggestions?
KristenChu
Peter and Mike,
I am trying to do the Extract Multi-values to Points tool as well. I am using version 10.8.1. I am getting two errors ( 010560 and 010167) when I try to run this tool. I have tried the above solutions but I am still getting both of these errors. Can you help? Thanks in advance!
