Extract by Attributes - Spatial Analyst Tool - Acceptable Fields in Query
1048
04-20-2010 11:40 AM
BrianCohen
Anyone know if you can use the Extract by Attributes tool with fields other than the Value field? I am trying to extract cells from the output of a COMBINE. This output naturally has multiple fields, and I want to use a query that involves those fields. However, I keep getting errors whenever I attempt to use a field other than Value. My grid is an unsigned integer, not floating pt, so according to the help pages I should be able to do so.
ToreBorvik
you should be able to query any field. can you provide a screenshot of attribute table and the error you get?
