Extract By Attributes failing - question about correct SQL input for raster data
7862
8
10-05-2015 02:19 PM
KaraJacobacci
I'm trying to extract only a certain value from a raster and display that as a new layer - I'm working with an Aspect raster derived from a DEM and want to select only Southwest (Class Value = 6) facing cells for display in a new layer.
I'm using the Extract by Attributes tool under the Spatial Analyst set.
Input raster is my aspect raster, for the SQL builder I was trying the following
"CLASS VALUE" = '6' (class value is a field that comes up when using the Identify tool on the layer).
It won't complete the process and gives me error 999999 [error executing function]
The Table was not Found
A column was specified that does not exist
Cannot acquire a lock
No Spatial reference exists,
Error 010213
Error 010325
Error 010067
Any idea why it won't complete/what steps I need to take to provide whatever information is missing? I have used the SQL builder a lot for vector data but not on raster data without an attribute table.
DanPatterson_Retired
Ahhhh it isn't reclassed...as I had assumed...which is what you have to do.  the quickest is to use reclassification and reclass everything < 202.5 to 0 and > 247 to 0 and between to 1, or you could query using 'Aspect_dem14' > 202.5 and 'Aspect_dem14' <247.5   of course not typing and I am pretty sure it is 'and' if it is there or perhaps & but think that may be bit-wise and.  Sorry I can't check...on an Arc-less iThingy​
did you type any of that expression?
I would check the query in the Raster calculator first
I you are using the raster calculator, select the field, equality sign and value from what is provided ...typing is not preferred
Sadly, there still exists a misnomer in equality checks that aren't standard.  In some places = is used, in others ==.  the latter is prefered, since = mean 'assignment' in most languages (of consequence)
If you are coding, check Specifying a query in Python—Help | ArcGIS for Desktop
KaraJacobacci
Thanks for the reply!
I did type the expression out (I'm aware of the pitfalls with typing instead of selecting from the lists... grrr) and I was wondering if that was the problem.
I don't fully understand the raster calculator - i can select the raster of consequence (aspect_dem14) but I do not understand what to choose from the right side column. Within the raster, there's a field called Class Value but I don't see where to select it. I've never used this tool before
screen shot of the raster table?  what type of raster?  esri integer grid perhaps?  ​
If it is an integer grid as described, then you should just be able to query the raster like
'myraster' == 6
since integer grids will contain a Value field and a Count field
KaraJacobacci
here's a screenshot. it's the 32 bit floating point type.
KaraJacobacci
The reclassification I think has solved my problem!! I was doing something similar to what you typed out in the Raster Calculator but I keep getting a syntax error. I think I'll stick with the reclassification!
Thanks a bunch!!
curtvprice
This is totally a job for Raster Calculator and the Con tool:
Con("Aspect_dem14" > 202.5 & "Aspect_dem14" < 247.5, 1, 0)
If you want to use SQL syntax you can but for continuous data I don't recommend it. (I find doing the straight Python a lot more flexible and easier to understand.)
Con("Aspect_dem14", 1, 0, "VALUE > 202.5 AND VALUE < 247.5")
KaraJacobacci
Thanks for the reply - I will be giving this a try too!
