extensions registraction problems !
1834
01-21-2013 12:41 AM
StefanieSchwarz
Hi
I use a  one year trial Version 9.3.1
When I started with the editor everything worked well.
Now I wanted to use the spatial analyst tools and registrated it through the deskop administrator. It shows me that I am now
registrated for spatial analyst until november 2013. But when I wanted to use the tool in Arc Map it says that I am not enabled to use it.
Has anyone an idea how to manage this? Or am i not allowed to use spatial analyst with the editor trial?
Pardosa
V_StuartFoote
Pardosa,
Even though authorized, you still need to enable each extension from the ArcMap Tools -> Extensions menu for use. Extensions are disabled by default.  Each should be enabled when needed, and then disabled when not being used.
Stuart
BubbaHey
As usual, Mr. F, you are right on the money.  This is a common complaint I hear from users. "But I authorized it and it's saying it's not licensed." Blah, blah, blah. LOl. Luckily, easy fix
