Error in Spatial Analyst - Band Collection Statistics
791
04-21-2011 09:30 PM
ReneeCatullo
Hi, I'm very new to ArcGIS and am trying to use it to run correlation matrixes between layers of worldclim variables (.bil).  When I run the Band Collection Statistics I get "error 010067: Error in executing grid expression.  StackStats Failed!"
I feel that the exclamation point is just a bit mocking, but that's besides the point.
Would anyone be able to help point me in the right direction for running a correlation matrix between all the layers?  I don't have enough of a background to understand what this error means and how to fix it.
Cheers,
Renee
JeffreySwain
Without knowing more about your data it is difficult to tell.  I would recommend considering the inputs to be sure they are in the same coordinate system or actually overlap.  Generally speaking, that error message has to do with the syntax of the command. So it either does not like the rasters being used or they do not match up as necessary in the tool.
Error Code
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//00vq00000003010067.htm
Band Collections
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//009z000000p5000000.htm
