Erase a polygon from a raster
4874
7
10-16-2010 07:55 AM
MarcusGriswold
Hi
I am attempting to erase a series of polygons from a raster set.  I have ArcView w/Spatial Analyst version 10.0.
I have converted the polygon to a raster and tried to subtract the two and have tried this code to no avail.
SetNull( Not IsNull( [PolyRaster] ), [MyRaster] )
Any help would be appreciated.
Marcus
DanPatterson_Retired
request that you General post be moved here...do not duplicate post, it isn't good for seaches
MarcusGriswold
Dan,
I am using ArcMap 10.  The error I received was a parsing syntax error. Maybe we can start with square one if you have time.  I have a raster and I want to erase the area of all polygons in a single shapefile from it.
MarcusGriswold
This is the error I received from that code:
Messages
Executing: RasterCalculator SetNull( Not(IsNull( "protect" )), "nlcdforse" ) C:\temp\privfor
Start Time: Thu Oct 21 15:08:06 2010
SetNull( Not(IsNull( Raster(r"protect") )), Raster(r"nlcdforse") )
ERROR 000539: Error running expression: rcexec() <type 'exceptions.NameError'>: name 'Not' is not defined
Failed to execute (RasterCalculator).
Failed at Thu Oct 21 15:08:06 2010 (Elapsed Time: 0.00 seconds)
Any thoughts?
Marcus
I can confirm that Not =! ~  the latter is used by 10 and note that there is no pop-up help or tool-tips to indicate so, so use ~ in place of Not and bookmark the page Bill referenced
MarcusGriswold
Great - Thanks! It would be great if there were a better error associated with it.
toddsams
Can this be done in SOMA tool? I tried and it gave a message that "Not" is not a valid operator (also tried ~). I am using 9.3.1
RafaelFernandes2
So I needed to do something like that, in 10. But in the result I get a raster without the erased parts, witch is good, but it also cuts other parts in my case, it cuts the top in a straight horizontal line, and the right side also in a vertical straight line.
Any suggestions?
