Enabling Spatial Analyst
1223
12-16-2010 03:00 PM
TexannaLandin
I got the trial of Spatial Analyst and enabled it but I cannot access the drop down menu. Please help!
DaveMcChesney
i had the same problem. arcgis 10 has changed from arcgis 9. apparently all the functions of the drop down menu are available somewhere in the "geoprocessing" menu drop down.
I'm trying to do a college project that is due in in early jan, and my university which was supposed to be open until then has closed down due to bad weather. I have a set of instructions based on an earlier version which is useless to me!!
V_StuartFoote
Don't panic... it's all still there!
In ArcGIS Desktop 10 ArcMap you'll find what you need on these main menu items:
[INDENT]Customize --> Extensions -- check box to enable Spatial Analyst
Customize --> Toolbars -- select Spatial Analyst
Geoprocessing --> Environments -- adjust the appropriate settings for your raster/grid analysis
[/INDENT]
Stuart
FrancisBoscoe
Glad I found this. This had me stymied for a few days.
