DEM Processing error
2312
06-03-2010 04:07 AM
achrajbhandari
Can any one help pls.I keep getting the following error. I want to delineate catchments using an SRTM 90 mts dem. When processing it gives me the following error.
DEM preocessing Error
RasterDataset::SaveAs failed (ERROR: #1007)
eimg_FileCopy failed (ERROR: #834)
RFInstanceFileCopy failed (ERROR: #7632)
FileCopy function failed (ERROR: #2450)
Stack trace:
   at ESRI.ArcGIS.DataSourcesRaster.ITemporaryDataset.MakePermanentAs(String new_name, IWorkspace Workspace, String Format)
DelineationExtension.CalculateFlowDirection(IRaster pDEM)
ProcessDEMForm.4(Object A_0, EventArgs A_1)
Thanx and regards
JosephArmbruster
I received the same error with the Highest Points Military Analyst Tool.
See below.
Joseph Armbruster
Running script HiLoByPolygon...
Could not read MA Options from registry.
Getting mean cell size: .\tmp18202622
Could not isolate HIGHEST points in surface.
Executing: SingleOutputMapAlgebra CON(tmp18202622 == tmp18202656,tmp18202622) .\tmp18202708 #
Start Time: Fri Jun 18 16:27:10 2010
ERROR 999999: Error executing function.
ERROR 010240: Could not save raster dataset to .\tmp18202708 with output format GRID.
Failed to execute (SingleOutputMapAlgebra).
End Time: Fri Jun 18 16:27:16 2010 (Elapsed Time: 6.00 seconds)
Completed script HiLoByPolygon...
Failed to execute (HiLoByPolygon).
DianeMcConnaughey
I got the same error message when copying a raster from one folder to another. ArcGIS 9.3.1.  The GRID seems to have copied over, and seems to be the same as the original.
Failed to paste
RasterDataset:saveAs Failed (Error: 1007)
eimg_fileCopy failed (error: #834)
RFInstanceFileCopy interupted (Error:#7635)
