dem analysis
7455
13
11-06-2013 11:43 AM
spencersawaske
I'm having trouble with what I think should be a relatively straightforward analysis of 10 meter dem data.  If you have a minute, could you offer any suggestions.
I am trying to calculate a sort of "exposure" score for every cell in a raster.  The basic idea is to compare the value of each raster cell with those nearby(200-400m radius).
E1= (# cells in surrounding area with elev.< cell  elev.)/(# cells in surrounding area with elev.> cell  elev.)
E2= (sum[cell elev.-(elev.of surrounding cells<gage  elev.)])/(sum[(elev.of surrounding cells>cell  elev.)-cell elev.])
For both indices, larger values represent locations with greater exposure and smaller values represent more protected, less exposed locations.  For instance, the E1 value for a location on top of a cone would be infinity, while that for the low point of an inverted cone would be 0.  I've been able to compute these indices for a small number of point locations using a combination of buffer and zonal tools.  Unfortunately, I'm now trying to perform this analysis for every cell in a much larger area(2-3 thousand cells) and my original method is no longer feasible.
I would greatly appreciate any suggestion you could offer.
spencer
808707
Ahh great thanks for the help Xander. I'll download the 32 bit version and see if that works.
Hello again. It looks like I got it working. I installed the 32 bit PyScripter and got the same error again. However I realised my DEM had a cell type of float and converted it to an integer and it seems to work okay with a cell size of 10m.
However I would like to see if this will work with a cell size of 0.2m. I tried this and a memory allocation error occurs. The same happened with 1m. Is there a limit to the resolution of the raster?
This got me thinking to this part of the code
# cellsize = 10m, distance of 200m = 20, window size will be 41
# half the window size (20 = 20 pixels * 10m/pixel = 200 meters, moving window = 420 * 420)
winhalf = 20
I was wondering how you calculated that the window size will be 41? and the winhalf will equal 20?
XanderBakker
Esri Esteemed Contributor
Hi Mark,
Basically the initial idea was a search distance of 200m (actually 200-400m, but I wanted to keep the array small). If you have a pixels size of 10m, a distance of 200m will be 20 pixels. So twenty pixels on each side means 20 * 2 = 40. When using filters and similar calculations, one uses an impair number of pixels to have a central pixel (the one where the value will be assigned). This is why the size is 41 pixels (2 * 20 + 1) and the winhalf is 20 pixels.
Kind regards,
Xander
Hello Xander. Thanks very much for the information. I'll play around with this some more and see what I can do.
