Creating a depressionless raster (Sinks and Fill)
7302
10
06-02-2011 11:48 AM
WesKing
I have run through determining an appropriate z limit for the Fill tool according to the help section..."Creating a depressionless DEM".
Following the steps outlined in the above help section, my output raster for the area I'm analyzing has a range of 6.10352e-005 to 0.680298
The help section seems to stop short of explaining how an appropriate z limit can be derived from the above process.
From the results I obtained above, what is an appropriate z limit?  Is it the max or the mean of the range, or maybe something totally different?
Thank you in advance,
Wes
curtvprice
Make sure you aren't resampling your data (for example, make sure the extent, snap raster, cell size, and coordinate system are not set (or at least not set to something different than the input raster.
