Correlation between two raster files - Correlation grid output?
3398
03-28-2011 03:58 PM
SethAdams
Hi all,
I have a question about calculating the correlation between two grids.  I am aware how to get a single correltation value as an overall correltaion value, but is there a way to produce a resulting grid with a correlation value for each cell?
I would like to have a visual aid for the correlation between the two variables over the entire study site ultimately.  I know the two attributes are closely correlated (using Spearman correlation), I just want to see over which areas the correlations are highest.
Thanks for any help,
Seth
SethAdams
Thank you Bill!  That is what I was referring to, I just could not think of the name or where I had seen something similar.
I will try out your suggestion and see what I can come up with!
Thanks for the help again,
Seth
SethAdams
Alright Bill, I ended up using your explanation found here:
http://forums.esri.com/thread.asp?c=93&f=1740&t=288054
It worked wonderfully, but when I received the output correlation grid, it had a high of 81 and a low of -81.  I know I saw another member on the forum have a similar situation arise and I can't quite seem to find the thread that the solution to their problem was located.  Can you help?  I'll keep searching though in the meantime.
Thanks again,
Seth
