Contour settings in feet
3660
09-02-2014 06:56 PM
jaredpilbeam
I'm attempting to create a contour map using a DEM file. I'm able to do it though I'm pretty sure it's measuring using metric, and I'd like to use feet. I somehow remember there being an option to change measurements in earlier versions of ArcMap?
Thanks in advance.
-Jared
DanPatterson_Retired
Check the help topic on Contour There is a z-factor that allows you to convert.
jaredpilbeam
THanks Dan,
I threw in 3.2808399 as the Z factor since that's how many feet are in a meter. It seems to have done the trick.
Best,
Jared
