Cell Statistics changing the raster extent
2699
08-08-2014 05:35 AM
EricaFonseca
Hi all,
I'm trying to combine two rasters datasets, the tool that seems more suitable is the Cell statistics. Despite it generates a new raster with the values of my old ones it is cutting the edges, so I don't have the original area.
Does anyone have a suggestion to fix this?
ps: the rasters files have different extents, the biggest is being cut and the other was generated from a point feature.
thanks in advance
DanPatterson_Retired
Mosaic to new raster would be a better tool to use.
In any event, when combining two rasters together, you must go to the Environments tab for the tool you are using in Arctoolbox and specify the cell size and extent to use.  This should be done as a matter of routine since not all tools honor all general settings.
