Building Raster from Coordinate Points (csv)
1354
11-16-2021 07:11 PM
BarrettLewis1
Hello, the goal of what I am trying to accomplish is to subtract the elevation values of one raster from another. I have a .tif file of one raster, and for the other, I have a .csv with coordinates and elevation values, from which I made a point feature. I've tried two things to turn the points into a raster or other:
1)Point to Raster
Point to Raster comes out the best, but some points out spread out too thin. Is there a way I can stretch values?
Interpolation didn't seem to be at all what I needed but I saw some suggesting it in previous threads. Any thoughts?
DanPatterson
MVP Esteemed Contributor
you could use
Extract Multi Values to Points (Spatial Analyst)—ArcGIS Pro | Documentation
and do the subtraction in the point featureclass rather than working with subtracting the rasters
... sort of retired...
JayantaPoddar
You could execute Topo to Raster (Spatial Analyst).
Input Feature Data Type: Point Elevation
Output Cell Size: Same as the other raster dataset
Primary Type of Input Data: Spot
In tool environment, define Snap Raster (Environment setting) to the other Raster Dataset.
Once the output Raster is created, you could execute Minus (Spatial Analyst) or use Raster Calculator.
Think Location
