Attribute streams with aspect
994
02-27-2014 09:17 PM
toddsams
Does anyone have thoughts on how to attribute stream segments with aspect?
I was thinking that the streams could be divided into segments of equal length to use for calculating average aspect (in degrees) for each segment. If a raster analysis of aspect is generated from the DEM, then the results from this raster surface  would need to be translated to a vector stream network, which is not fully aligned with the DEM-based stream network.
Many thanks in advance for any ideas on an approach.
MarkBoucher
Honored Contributor
Sounds like a similar topic to this other recent post. http://forums.arcgis.com/threads/103132-Obtaining-stream-flow-direction
