arcmap keep crashing when using zonal statistics as table
1716
03-08-2012 10:03 AM
XiaoningHe
Hello. I've got a problem when using the tool zonal statistics as table. I tried two feature layers as input zone, WV county boundaries map and WV census track map. The tool runs ok with the
county map but keeps crashing the arcmap every time when dealing with the census track map. The arcmap just close without any error message nor anything. The arcmap version is 10 with SP3.
I guess the problem maybe is the census track map has much more elements than county map(484 vs. 55). Anyone can help me? thanks a lot!!!
DanPatterson_Retired
the size of the files could be the reason, but make sure that the origin and destination folders don't contain spaces, a common problem with SA functionality
