Alignment between raster and shapefile problem
1586
01-22-2020 02:58 AM
RobertoFilloramo
I am using ArcMap 10.1, I am getting some trouble because of the alignment between the raster (slope) and its coastline (shapefile). They seem to have the same coordinates, but there is no match.
Here the shapefile data (geometry type - Line):
Projected Coordinate System:    WGS_1984_UTM_Zone_33N
Projection:    Transverse_Mercator
False_Easting:    500000,00000000
False_Northing:    0,00000000
Central_Meridian:    15,00000000
Scale_Factor:    0,99960000
Latitude_Of_Origin:    0,00000000
Linear Unit:     Meter
Geographic Coordinate System:    GCS_WGS_1984
Datum:     D_WGS_1984
Prime Meridian:     Greenwich
While attached you will find the slope spatial reference and a sample of the overlapping between both.
Could someone help me?
thank you in advance
