Will the Utility Solutions (UtilSolutions) CCTV Management Toolset be Upgraded to Work with Latest NASSCO Version 8?
1148
03-03-2026 07:46 AM
DirkMahogany
I’ve recently learned that the latest NASSCO CCTV Assessment Standard (Version 8.) is moving away from Microsoft Access databases and transitioning to SQLite (.db3).
Given this change, I’m wondering if ESRI has plans to update the Utility Network Solutions CCTV Manager Toolset to support importing tables from SQLite database formats. At the moment, the toolset only supports converting MS Access tables into a file geodatabase, which may limit compatibility with the upcoming NASSCO standard.
Our team relies heavily on this toolset to integrate CCTV inspection data into our central GIS database, so understanding the future of this toolset would be helpful.
Utility Solutions CCTV Manager Toolset: An overview of the CCTV toolset—Utility Solutions toolbox | Documentation
AyanPalit
AyanPalit
@DirkMahogany A update to CCTV Program solution is planned as in:
https://www.esri.com/arcgis-blog/products/arcgis-solutions/announcements/arcgis-solutions-2026-produ...
Ayan Palit | Principal Consultant Esri
DirkMahogany
@AyanPalit That’s great news, and I really appreciate the quick response.
I also came across this LinkedIn post that provides a bit more detail, sharing it here in case others find it helpful as well.
Introducing ArcGIS CCTV Program Management Solution | Alex Kabak posted on the topic | LinkedIn
