Using Conditional Formatting to Populate a New Field Using Field Calculator.
5103
5
09-25-2015 05:04 PM
BillFearrington
I am trying to use conditional statement to populate a new field using the Field Calculator.  I have a column named "Days from Appt."  I would like the field to populate if less than 7 days "One week or less."  I named this new column Duration.  Can someone please help a newbie to programming with this?  Can either  be in VB or Python. Thanks.
Tags (1)
DanPatterson_Retired
Since you only have one condition why not make it quick
  • make a text field if not already done
  • query your Days from Appt field for values < 7 assuming it is numeric (won't matter if it is text unless >= 10)
  • go to your new field and use the field calculator to past in "One week or less"
  • switch the selection, type/select  str(  ) and select your source field  so it yields  str(!your really long field name above!) enclosed in ! marks if using Python...
or in totally untested code and assuming your source field is numeric
python parser
def appt(input_field):
    """no error checking"""
    if input_field < 7:  # assuming a numeric field otherwise int(input_field)
        val = "One week or less"
    else:
        val = str(input_field)
    return val
field expression  !your_field_here!
obviously changing !your_field_here! to you know, your field
BillFearrington
Thanks for your response.  I forgot to mention that I need to have several if statements.  I will have 8-14 days = Two weeks or less, 15-21 = Three weeks or less.  Also I have negative days which will be greater than one week, etc.
BillFearrington
Also I tried this before I left for the day.  I would put the code in the code block and what would I use
for the box under the code block?
the !your_field_here!
for homework...
if a < 7:
  val = do blah
elif (a >= 7) and (a < 14):
  val = more blah
else:
    val = final blah
return val
BillFearrington
Thanks for your help.  I'll have to give it a try on Monday.  Wish Me Luck.  🙂
