Use Business Analyst Network Dataset Standalone?
5320
08-07-2014 09:07 PM
RobertStevens
I am trying to use the network dataset that ships with business analyst
(version 10.0  in StreetMapData/streets.sdc) to solve a routing
problem outside the confines of the Business Analyst wizards.
When I try and add this dataset to a map I do not get the
result I would expect. In particular the Network Analyst window
doesn't show anything and so I cannot enter the parameters
needed for the problem in question.
Why is that? Is it because Network Analyst does not
understand .sdc files?
Jason_RobinsonRobinson
Robert,
This is somewhat related to your other post but you will need to run the data install from BA10.1 2011/2016 as well as using that versions .sdlic license file to be able to the network dataset for 2011/2016 (Navteq).  You might need to check in with Esri Customer Service to be able to download the 10.1 2011/2016 data install from My Esri.
Regards,
Jason R.
