Tree Management Solution- updated Species Roster is not reflected in fields in Trees Feature Layer
444
10-15-2025 06:35 AM
scottmuscatello
Hello!  I have recently deployed the Tree Management Solution and am following instructions to Configure and Use.
I updated the Species Roster and then Ran the Species Roster Notebook.
However, I am not seeing the updates in the Trees Feature Layer-- for example, I am updating Fields under Data and the Genus and Species Domain lists do not reflect the updated Species Roster.
Please let me know how to proceed.
Thank you!
Eric_Purdy
Hi @scottmuscatello
Are you in Enterprise or ArcGIS Online?
Is the notebook throwing any errors when you run it? If so, can you share what those errors are?
If the notebook isn't giving you any errors, can you share a little more info about the workflow you used to change the species roster?
