Segmentation Errors
3228
01-12-2011 07:21 AM
PaulAmos
I'm getting all kinds of errors when I try to create a Customer Profile from the Target Marketing optin in the Business Analyst menu. If I "Geocode an existing table" and assign it an excel spreadsheet, I accept all the defaults, the table geocodes, but I get Error 08001 once the geocoding is completed. If I use the "Address Coder" option in the Create customer Profile, I enter all the information and get a Range Check Errormwhen I try to run Address Coder.
Any suggestions? Thanks!
Jason_RobinsonRobinson
More often than not geocoding errors tend to stem from issues with the input table being used.  A good test, after restarting Business Analyst, is to use the same workflow but using the sf_custs.dbf which is part of the tutorial data.  It can be found at at this location for BA10:
C:\Program Files\ArcGIS\Desktop10.0\Business Analyst\Datasets\Tutorial
Lets see if you encounter the same error or if it will process normally.
Regards,
Jason R.
