Lead Service Line Solution - data distribution
602
03-07-2025 12:50 PM
bsanders69
I installed the Lead Service Line Solution in 2023 to Enterprise 10.9.1 and I just looked at the FDGB, Toolbox, sources.  The ArcPro project sources were all over the place.  It put some in my local user folder with the following paths:
Home folder: ...\Documents\ArcGIS\Packages\missing name_71be06
Default geodatabase:  ...\Water\Lead\Lead Service Line\LeadServiceLine.gdb
Default Toolbox:  ...\Documents\ArcGIS\Packages\missing name_71be06\LeadServiceLineInventory_DataManipulation.tbx
Project location (correct):  M:\GIS Team\Projects\LeadServiceLineInventory\LeadServiceLineInventory_DataManipulation.aprx
Pro is set up on our machines to put everything that makes up the project in a (provided) folder.  There should be a method that will put Pro Projects in a folder as if you are creating a new project so that data, tools, and Home folder are not spread all over the place.  Any idea why it did not give it its own folder or ask for a place to put the Project(s) when installing the solution?.  I have a big mess to clean up.
