How to Create a Spatial Reference for Hot Spot Analysis
1916
01-20-2012 01:30 PM
JimMcIntosh
I'm trying to run a hot spot analysis using multiple variables.  The analysis is working fine, but I end up with a shapefile without any spatial reference.  How can I add an xy or anything else that would allow me to define the projection?
Jason_RobinsonRobinson
Brian,
Just going on memory I believe that was an issue that a Business Analyst Service Pack has fixed.  If you open the Message Center and look at the Software & Data section it should give a build number as to the current version if you are not sure which you are on.
Regards,
Jason
