GIS Request Management - GIS Service Request Form
2194
11
02-23-2026 08:13 AM
StephenKing3
Hello,
I'm looking for some advice on the settings for the GIS Service Request Form. In the Share survey settings it says that 'Members of my organization (ArcGIS Enterprise)' can submit to the survey. However, for users with a 'viewer' licence, they get the error 'You cannot submit records to the survey since you do not have the Edit privilege'. I can see from the survey123 requirements (System requirements—ArcGIS Survey123 | Documentation) that the viewer licence can only submit to public surveys. The majority of our users will only have the viewer licence but I don't want the survey to be public .... however, is the only way around this to make the survey public?
Stephen
2 Solutions
Joshua-Young
MVP Regular Contributor
@StephenKing3 one thing you can try is to add a text field to your survey, have it ready only and required, and set the constraint to a GUID. Then update the link to your survey URL to include "?field:surveyid=<GUID>" at the end of the link. Do not include the "?" if it is already in the URL. You could even go a step further, add "?field:surveyid=<GUID>&encodeUrlParams=true", and reload the page to get an encoded URL so your users cannot change the GUID. I recommend changing the pocname and pocemail fields to not auto populate because it will be blank for your viewer users.
Once you have the URL with the suveyid included, make sure you set the GIS Service Center and Service Portal hub pages to not be public so the public cannot access the URL with the surveyid. The survey must be set to public for this to work. When a viewer license clicks the survey link, they should be taken to the survey form but not signed in. That is what happens on ArcGIS Enterprise 11.5.
To recap:
  1. Add a surveyid field to the survey in Survey123 Connect that is read only, required, and has a constraint set to a specific GUID
  2. Change pocname and pocemail to be required, remove the readonly flag, and remove the pulldata calculation
  3. Set the GIS Service Center and Service Portal pages to not be public
  4. Add to the end of the survey URL on the Service Portal page "?field:surveyid=<GUID>"
  5. Make the survey public
  6. (Optional) Periodically change the GUID in the constraint rule and URL for improved security
Here is what I have in Survey123 Connect for one of our surveys. I removed the GUID so you will need to enter your own. I found constraint rules do not work if the field is hidden, so do not hide the surveyid field.
typenamelabelhintguidance_hintappearancerequiredrequired_messagereadonlydefaultcalculationconstraintconstraint_messagerelevantchoice_filterrepeat_countmedia::audiomedia::imagebind::typebind::esri:fieldTypebind::esri:fieldLength
textsurveyidSurvey ID   yes yes  .= "<Enter a GUID Here>"Survey ID Required      esriFieldTypeString
255
"Not all those who wander are lost" ~ Tolkien
Joshua-Young
It is my understanding the 'Add and update records (read access enabled)' is for when you want people to be able to change a submitted survey. Which is okay when the survey is not public and you do not care if your organization members see the results.
In the solution I mentioned above the survey needs to be 'Only add new records'. You will need to make a few changes for the My GIS Request dashboards to work properly.
  • You will need to modify the My GIS Requests dashboard to point to GIS_Activities_public using ArcGIS Online Assistant to swap out the item IDs.
  • Update the GIS_Activities_public view to include the Comments table and be sure to set a filter for "Visible to Requester = Yes". The GIS_Activities_public should not be shared with the public despite the name.
  • In the My GIS Requests dashboard in the Category Selector
    • Click Edit in the layer section
    • Change line 9 to
usernames['features'][0] = {attributes : {username: user['fullName'], blank: '.'}}​​
  • Update the filter action to target the Name field under Request List
With those changes the My GIS Requests dashboard will filter the requests based on the name provided in the pocname field which you will need since the createdby field is now blank because it is a public survey. I hope this helps.
DanielWickens
@StephenKing3 - Yes, sharing publicly is the only way to allow users with a 'Viewer' license to submit the GIS Service Request form. Many other organizations have done this with the form. The only other option would be to elevate the users that need to submit up to 'Contributor' licenses to keep the form shared only to the organization, but that can be difficult depending on the size of your organization.
StephenKing3
Thanks Daniel, I suspected that would be the case. Yes, it would be difficult to make users contributors with additional licence costs. We will need to make the form public and one problem I see with this is that potentially people can submit requests without signing in, so we wouldn't see who they are from.
DanielWickens
One option to help with that is to do part of what @Joshua-Young suggested:
Change pocname and pocemail fields to be required, remove the readonly flag, and remove the pulldata calculation.
This will allow you to share the survey form publicly, but still require anonymous users to provide their name and email before they can submit the form.
Joshua-Young
To recap:
255
StephenKing3
Thanks @Joshua-Young and @DanielWickens for your help. I haven't tried to fully implement this, but something that concerns me in making the survey form public is the warning that you get in survey123 that says survey responses will be exposed. This is if you select the setting 'Add and update records (read access enabled)' in the Share survey tab. It seems that you have to allow this setting otherwise the status of the submission is not visible to the use on the service portal page. Is that correct? If so, are all user submissions effectively open to anyone outside the organisation to see?
Joshua-Young
    • Change line 9 to
StephenKing3
Hi @Joshua-Young, thanks again for your help. I had to reinstall request management to get things working again. I’ve worked through your solution above and almost had it working, except getting the request status update to work. I can’t see where to make the changes to the filter in the Category Selector you mention. Is this something additional that I need to add to the dashboard settings?
StephenKing3
Thanks again @Joshua-Young, I have managed to part implement your solution but have hit another stumbling block. The GIS Service Request form is submitting correctly and updating the associated feature layer, but my GIS_Activities feature layer is not updating with the new records - I must have broken something somewhere. Do you have any ideas what to look at? I haven't been able to track down the link between the two.
Joshua-Young
@StephenKing3 that is odd since the GIS_Activities feature layer is the root service for all the request/activities views. If you check the Data tab in the GIS_Activities item page is it empty as well, or is it the My GIS Requests dashboard that is empty?
