GIS Request Management - GIS_Activites_surveys (hosted,view)
600
03-23-2026 09:46 AM
TexasMike
I enabled sync on the GIS_Activites_surveys feature layer(hosted,view). Unfortunately, this caused some issues and the layer no longer resolves with data. Is there a way for me to revert this back? Since the GIS Activities Dashboard uses this view it also isn't working. I'm on Portal 11.3 @BrandiRank22
BrandiRank22
It's going to be a lot easier for me to help you if we get on a call.  I will DM you my email.  Since I won't be able to meet until later this week / next week you could also think about submitting a ticket with help - they might be able to help a little faster.  Contact Esri Technical Support
BrandiRank22
How did you enable sync on the GIS_Activities_surveys feature (hosted,view)?  Can I assume you also had to enable sync on GIS_Activities(hosted)?  Did you try to disable sync on the GIS_Activities first?
TexasMike
I just checked the option to enable sync on the GIS_Activities_surveys item page under settings in Portal. Yes I did enable sync GIS_Activities(hosted) as well. Once I realized something was wrong I did disable sync on both of them. I get errors in the browser like field name not found. I think I messed up the view definition when I enabled sync. Is there a way to find or do you have the definition for that view? I think it was a join and I've read (after the issue) enabling sync on those layers can cause issues.
BrandiRank22
