Creating Trade Areas From Existing Polygons
2485
06-19-2013 12:24 PM
GarriGrossi
I'm creating reports for Trade Areas based on an existing polygon layer. Is there a way to use my poly layer to define these trade areas (other than the hand draw tool)?
Garri
Jason_RobinsonRobinson
Garri
Garri,
It sounds like you were using the hand draw tool to basically trace over another existing polygon layer in your table of contents.  If this is the case you can save yourself some time as you can run reports on any polygon layer and would not have to use the hand draw trade area tool.
Regards,
Jason R.
