Capital Project Coordination - template default values are greyed out
1672
03-28-2025 09:35 AM
JamesBurton1
Working on deploying the new Capital Project Coordination solution and hit a road block in the "Configure Project Types" step 15 of this setup page. Using the Field Maps Designer, I added a new template for a new project type called "Study" by following the instructions to copy the "Other" template. Now I can't change the "Other" value to "Study" as the default value for the Project Type field. It provides a tip on step 15 to remove the default value from the Project Type field, but with the field greyed out, that is not possible. Anyone know what I'm missing?
JamesBurton1
Another road block I found. In Update project map step 12 tells you to open the Forms in the Capital Project Catalog web map, but I don't have the forms as an option in the web map with the Projects layer selected.
AndyShoemaker
Hi James,
Sorry to hear you are hitting some issues. I've followed the workflow myself and it seems to work for me.
Do you know what role you have in your organization? I'm wondering if that could be preventing the template updates.
As for the second issue, the latest release of ArcGIS Online had a small change in where the Forms button can be found. It is now nested underneath the "Configure Editing" button.
Andy
Andy Shoemaker
JamesBurton1
Hey Andy,
I'm an Admin, so, I'm not sure why I can't change that default value. I guess it will be a problem for another day and I'll live with the existing project types.
Your tip about the placement of the forms and template buttons solved my second question! Funny how a simple thing like that can hold you up.
Appreciate your reply.
