Attribute Assistant Add Calculate USNG
1863
10-29-2014 10:38 AM
Status: Open
MichaelDawson1
Please add a method to the Attribute Assiant to have a field calculate the 1k USNG number
3 Comments
KoryKramer
Hi Michael Dawson‌.  Can't you just set up the Intersecting Feature method with the USNG 1k polygon layer as the Input in the Value Info?  Intersecting features - Attribute Assistant | ArcGIS Solutions
JoeBorgione
Exactly what I was thinking....
DEWright_CA
If you are selecting a point based on the map; what are you only doing a centroid of a 1k Poly? The full calculated location should be able to be returned.
