Emergency Management Operations Solutions 2026 Infographic variables.
187
07-02-2026 02:47 PM
With the June 2026 update to ArcGIS Online, new data sources were introduced for the Emergency Information infographic. If you receive the following message when running the infographic:
"This Business Analyst widget is configured with a data source that has been deprecated. Please update to the latest available data sources."
you will need to update the Emergency Information Manager Experience Builder app to use the new data source. Follow the steps below to reconfigure the infographic.
  1. Sign in to your ArcGIS organization and browse to the Emergency Information Manager Experience Builder item.
  2. Click Edit.
  3. On the left panel of the Experience Builder project, click Page.
  4. Under Page, select Understand Impact.
  5. Click the Business Analyst widget in design mode.
  6. Expand the Location and Data setting.
  7. Check Use latest data source.
  8. Expand the Infographics setting.
  9. Click Select an infographic.
  10. Expand Esri Infographics.
  11. Select Emergency Information.
  12. In the upper right of Experience Builder, click Save.
  13. Click Publish.
You now may run the Emergency Information Manager and use the infographic that will utilize the latest data source.
Version history
Last update:
‎07-02-2026 02:47 PM
Updated by:
Contributors
