Javascript coding help
2576
02-12-2016 05:27 AM
Muqit_Zoarder
Dear all, good day to all of you. Please help me in following coding. I want to view the legend which layers are visible through in click event or active in the map scale. I tried several ways but could not make it run. I have another problem with getting feature information. From the present coding i am getting the on click event feature information from a feature layer but I want it from the active top-most layer. Now when I switch off all layer even though the feature information is coming. Please see the screen shorts.
<!DOCTYPE html>
<html>
<head>
        <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
        <meta http-equiv="X-UA-Compatible" content="IE=Edge" />
        <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
        <title>Dresden Building Web Map</title>
        <link rel="stylesheet" href="http://js.arcgis.com/3.15/esri/css/esri.css">
        <link rel="stylesheet" href="https://js.arcgis.com/3.15/dijit/themes/claro/claro.css">
   <style>
      html,
      body {
      height: 97%;
      width: 98%;
      margin: 1%;
      #HomeButton {
      position: absolute;
      top: 95px;
      left: 20px;
      z-index: 50;
        #layerListPane{
        width:15%;
      #ins {
        background: #fff;
         color: #444;
         position: absolute;
         font-family: arial;
         height: 100px;
         right: 30px;
         margin: 5px;
         padding: 10px;
         top: 0px;
         width: 300px;
         z-index: 40;
        h1{
           text-align: center;
        h2 {
                text-align: center;
                margin: 4px 0;
      h3 {
         margin: 0 0 5px 0;
         border-bottom: 1px solid #444;
      .shadow {
         box-shadow: 0 0 5px #888;
      #map {
         margin: 0;
         padding: 0;
      #feedback {
         background: #fff;
         color: #444;
         position: absolute;
         font-family: arial;
         height: 300px;
         left: 25px;
         margin: 5px;
         padding: 10px;
         top: 170px;
         width: 300px;
         z-index: 40;
      #note,
      #hint {
         font-size: 80%;
      #note {
         font-weight: 700;
         padding: 0 0 10px 0;
      #layerList {
         width: 200px;
      .dojoDndItemOver {
         background: #ccc;
      #search {
                display: block;
                position: absolute;
                z-index: 2;
                top: 25px;
                left: 80px;
            #topPane {
      width: 10%;
            #rightPane {
      width: 15%;
    #legendPane {
      border: solid #97DCF2 1px;
   </style>
   <script type="text/javascript">
            dojoConfig = {
                parseOnLoad: true,
                isDebug: true
        </script>
   <script src="https://js.arcgis.com/3.15/"></script>
<script>
      var map, layer, iTask, legendMap, visible = [];
      require([
        "esri/map",
        "esri/layers/FeatureLayer", "esri/dijit/Legend",
        "esri/layers/ArcGISDynamicMapServiceLayer",
        "esri/dijit/Geocoder",
        "esri/tasks/IdentifyParameters",
        "esri/tasks/IdentifyTask",
        "esri/InfoTemplate",
        "esri/dijit/Scalebar",
        "esri/dijit/BasemapGallery",
        "esri/arcgis/utils",
        "esri/dijit/HomeButton",
        "dojo/dom",
        "dojo/query",
        "dojo/on",
        "dojo/parser",
        "dojo/_base/array",
        "dijit/layout/BorderContainer",
        "dijit/layout/ContentPane",
        "dijit/TitlePane",
        "dijit/layout/AccordionContainer",
        "dojo/domReady!"
      ], function(
        Map, FeatureLayer, Legend, ArcGISDynamicMapServiceLayer, Geocoder,
        IdentifyParameters, IdentifyTask, InfoTemplate,
        Scalebar, BasemapGallery, arcgisUtils, HomeButton,
        dom, query, on, parser,
        arrayUtils
        parser.parse();
        map = new Map("map", {
          basemap: "topo",
          center: [13.7383200, 51.0508900],
          zoom: 13
        layer = new ArcGISDynamicMapServiceLayer("http://192.168.224.16:6080/arcgis/rest/services/Dresden/MapServer");
        iTask = new IdentifyTask("http://192.168.224.16:6080/arcgis/rest/services/Dresden/MapServer");
        legendMap = new FeatureLayer("http://192.168.224.16:6080/arcgis/rest/services/Dresden/MapServer/0", {
        mode: FeatureLayer.MODE_ONDEMAND,
        outFields:["*"]
         layer.on("load", buildLayerList);
        map.addLayer(layer);
        function buildLayerList() {
          var items = arrayUtils.map(layer.layerInfos, function(info, index) {
            if (info.defaultVisibility) {
              visible.push(info.id);
            return "<input type='checkbox' class='list_item'" + (info.defaultVisibility ? "checked=checked" : "") + "' id='" + info.id + "'' /><label for='" + info.id + "'>" + info.name + "</label>";
          var ll = dom.byId("layer_list");
          ll.innerHTML = items.join(' ');
          layer.setVisibleLayers(visible);
          on(ll, "click", updateLayerVisibility);
        function onIdentifyComplete (results) {
                    return arrayUtils.map(results, function (result) {
                        var feature = result.feature,
                            title = result.layerName,
                            content;
                        switch(title) {
                            case "gis.osm_buildings_v06":
                                content = "${*}"; //"OSMID: ${osm_id}<br />CODE: ${code}<br />TYPE: ${type}";
                                break;
                            /*default:
                                content = "${*}";*/
                        feature.infoTemplate = new InfoTemplate(title, content);
                        return feature;
                function onMapClick (event) {
                    var params = new IdentifyParameters(),
                        defResults;
                    params.geometry = event.mapPoint;
                    params.layerOption = IdentifyParameters.LAYER_OPTION_ALL;
                    params.mapExtent = map.extent;
                    params.returnGeometry = true;
                    params.width = map.width;
                    params.height= map.height;
                    params.spatialReference = map.spatialReference;
                    params.tolerance = 3;
                    defResults = iTask.execute(params).addCallback(onIdentifyComplete);
                    map.infoWindow.setFeatures([defResults]);
                    map.infoWindow.show(event.mapPoint);
                function onMapLoad() {
                    map.on("click", onMapClick);
                //map.addLayer(layer);
                if (map.loaded) {
                    onMapLoad();
                } else {
                    map.on("load", onMapLoad);
        function updateLayerVisibility() {
          var inputs = query(".list_item");
          var input;
          visible = [];
          arrayUtils.forEach(inputs, function(input) {
            if (input.checked) {
              visible.push(input.id);
          //if there aren't any layers visible set the array to be -1
          if (visible.length === 0) {
            visible.push(-1);
        var legendDijit = new Legend({
            map: map,
            respectCurrentMapScale= true
          }, "legendDiv");
          legendDijit.startup();
        var home = new HomeButton({
        map: map
        }, "HomeButton");
        home.startup();
        var scalebar = new Scalebar({
          map: map,
          // "dual" displays both miles and kilmometers
          // "english" is the default, which displays miles
          // use "metric" for kilometers
          scalebarUnit: "dual"
        //add the basemap gallery, in this case we'll display maps from ArcGIS.com including bing maps
        var basemapGallery = new BasemapGallery({
        showArcGISBasemaps: true,
        map: map
        }, "basemapGallery");
        basemapGallery.startup();
        basemapGallery.on("error", function(msg) {
        console.log("basemap gallery error:  ", msg);
        var geocoder = new Geocoder({
            map: map
         }, "search");
         geocoder.startup();
        //add the legend
      map.on("layers-add-result", function (evt) {
        var layerInfo = arrayUtils.map(evt.layers, function (layer, index) {
          return {layer:layer.layer, title:layer.layer.name};
        if (layerInfo.length > 0) {
            map: map,
            layerInfos: layerInfo
          }, "legendDiv");
     map.addLayers([legendMap]);
    </script>
</head>
<body class="claro">
   <div data-dojo-type= "dijit/layout/BorderContainer"
        data-dojo-props= "design: 'headline', gutters: true"
        style="width: 100%; height: 100%; margin: 0;">
            <!--<div id="layerListPane" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'left'">
                <div id="layer_list"></div>
            </div>-->
        <div id="topPane" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'top'">
            <div  style="float: left; eft: 10px; position: relative; top: 4px;">
                <img src="images/zalf_logo1.jpg"/>
                            </div>
            <h2>BUILDING INFORMATION WEB MAPPING OF DRESDEN </h2>
        </div>
        <div id="rightPane" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'right'">
            <div data-dojo-type="dijit/layout/AccordionContainer">
                <div data-dojo-type="dijit/layout/ContentPane" id="legendPane"
                    data-dojo-props="title:'Legend', selected:true">
                    <div id="legendDiv"></div>
                </div>
                    data-dojo-props="title:'Pane 2'">
                    This pane could contain tools or additional content
                </div>
            </div>
        </div>
        <div id="map" class="map"
                data-dojo-props="region:'center'"
                style="overflow:hidden;">
                <div id="HomeButton"></div>
                <div id="search"></div>
            <div style="position:absolute; right:30px; top:150px; z-Index:999;">
                <div data-dojo-type="dijit/TitlePane"
                    data-dojo-props="title:'BaseMap Gallary', closable:false, open:false">
                        <div data-dojo-type="dijit/layout/ContentPane" style="width:380px; height:280px; overflow:auto;">
                                <div id="basemapGallery"></div>
                        </div>
                </div>
            </div>
            <div id="ins" class="shadow">
                    <!--<h2>BUILDING INFORMATION WEB MAPPING OF DRESDEN </h2>-->
                    <p>Click on the map to view the building information data of Dresden. This is based on open source data.</p>
            </div>
            <div id="feedback" class="shadow">
                <!--<h3>Layers</h3>
                <div id="info">
                    <div id="hint">
                        Click and drag a map layer name below to re-order layers. The first layer in the list will be drawn on top.
                    </div>-->
                    <strong>Map Layers</strong>
                </div>
            </div>
        </div>
    </div>
</body>
</html>
Regards
Muqit
AmandaManning
I'm not sure, but it looks like you need to assign the layers to "new featurelayer" Legend | ArcGIS API for JavaScript
Have you looked/tried this example?
