Issue with ArcGISDynamicMapServiceLayer Not Working on a Service
2262
07-29-2015 10:15 AM
AnthonyDaniels
I am working on an 3.14 js api web app and the issue is that ArcGISDynamicMapServiceLayer is working on 2 of my services, but not on my third.  I look at the REST it shows up fine.  I have check the URL many times but when I try to add the layer to my map, it crashes.
m_allDistLayers = new esri.layers.ArcGISDynamicMapServiceLayer("http://newecho:6080/arcgis/rest/services/DAMP/dareas/MapServer");
m.map.addLayer(allDistLayers);
ReferenceError: m is not defined
    at loadLayers (http://localhost/DAMP/js/Default.js:171:2)
    at http://localhost/DAMP/js/Default.js:104:18
    at b.ready.b.addOnLoad.e (http://js.arcgis.com/3.14/init.js:235:451)
    at g (http://js.arcgis.com/3.14/init.js:235:179)
    at http://js.arcgis.com/3.14/init.js:9:412
    at a (http://js.arcgis.com/3.14/init.js:5:295)
    at r.signal (http://js.arcgis.com/3.14/init.js:9:382)
    at ia (http://js.arcgis.com/3.14/init.js:23:112)
    at fa (http://js.arcgis.com/3.14/init.js:23:144)
    at g (http://js.arcgis.com/3.14/init.js:25:375)
info: m is not defined
All other services are off the same ArcGIS Server 10.3.1 and are working without issue  Example:
m_census = new esri.layers.ArcGISDynamicMapServiceLayer("http://newecho:6080/arcgis/rest/services/DAMP/census/MapServer");
m_map.addLayer(m_census);
m_crime = new esri.layers.ArcGISDynamicMapServiceLayer("http://newecho:6080/arcgis/rest/services/DAMP/crime/MapServer");
m_map.addLayer(m_crime);
Anthony
AnthonyDaniels
I found my error
