Can web app builder consume REST services that are not associated with a web map
2839
07-28-2016 11:34 AM
AntoineBartholomew
Does anyone know how to consume REST services within Web app builder, that are not added into the initially created web map.  I want to be able to work with (consume) services without linking the service into the web map.
If I want to add a REST URL into my map, without adding the REST service into a Web Map (1st); can I use the FeaturelayerServiceBrowser class to accomplish this?  https://developers.arcgis.com/web-appbuilder/api-reference/featurelayerservicebrowser.htm
How can I add data layers to the Web APP without first adding the layer into a web map?  Can I directly pull JSON (GeoJSON?) data into the web map like this:
http://www.geothread.net/importing-geojson-data-in-arcgis-javascript-maps/
https://community.esri.com/thread/17970
All I can find is the link below that says this type of work flow is not supported.
https://blogs.esri.com/esri/arcgis/2015/04/06/clarifying-3-questions-about-web-appbuilder-for-arcgis...
