WGS84 Maps URL
1489
04-09-2013 01:52 AM
StanleyHo
Is ESRI providing any WGS84 maps?
If so, can point me or provide me with the url?
Mercator maps latitude range is only -85 to 85 degree which will post a problem for the application that I am working on.
thanks.
MichaelBranscomb
Esri Frequent Contributor
Public services are now only available in the Web Mercator coordinate system. You can check the support status here: http://downloads2.esri.com/support/product%20life%20cycle/online_gis/ArcGISOnlineServ_PLC.pdf.
ArcGIS can host your own tiled map services for you. In order to do this you'll need an Organizational account - see http://resources.arcgis.com/en/help/arcgisonline/index.html#/Hosted_tiled_map_services/010q0000006n0... for more info.
Cheers
Mike
DominiqueBroux
Examples of WGS84 basemaps:
  -  Street Map
  - Imagery
StanleyHo
thanks for your reply.
The maps that you posted are in extended support and no longer updated.
Is there any WGS84 map that is still in support?
MichaelBranscomb
Cheers
Mike
StanleyHo
Ok. Thanks
