using GetItemsSync and GetGroupAsync in same class
1355
11-22-2013 06:01 AM
HumzaAkhtar
I am implementing a function which will take username and ID of a person and then list the maps in the root folder and maps in the groups shared by that person in a separate UI. I am putting the results from both GetGroupAsync and GetItemsSync in an array. The idea is to call the new list box class constructor with the array as an argument after both async methods have finished.
Now my problem is that where can I call the constructor of new class. There are three possibilities with three issues
1. put the
nextUI = new Listboxconstructor(array);
in the GetItemsAsync method. The problem is that I dont get the items from the GetGroupsAsync as that method is running in separate thread.
2. put the
in the GetGroupsAsync method. The problem is that I dont get the items from the GetItemsAsync as that method is running in separate thread.
3. put the
in the main thread. The problem is that I dont get the items from from any method as both methods are running in separate threads.
Any workaround for this issue will be appreciated.
ThadTilton
If you are developing on .NET 4.5, I'd recommend using the task-based asynchronous pattern described here:
http://msdn.microsoft.com/en-us/library/vstudio/hh156513.aspx
Otherwise, you can leverage delegates and BeginInvoke to implement a solution that works across multiple threads. See the example here:
http://www.codeproject.com/Articles/100184/How-to-Manage-Multiple-Asynchronous-Calls-by-using
hope that helps! Thad
ThadTilton
HumzaAkhtar
Dear Thad,
Thanks for the reply. I will use BeginInvoke and EndInvoke
