Using Editor class to move MapPoint objects.
2200
02-13-2013 07:37 AM
NickKohler
We just updated to version 10.1.1 and seem to be having an issue with the Editor class. When enabling the EditVertices mode and moving a MapPoint, the EditCompleted event is not being raised to indicate the move as it did with the 2.4 version of the toolkit. Has the design changed so that moving a MapPoint geometry object requires some other mechanism, or should the event be raised? Has anyone else had an issue? Just to clarify, we are not using the EditorWidget, just the Editor class.
PreetiMaske
This looks like a bug. I assume it got introduced as part of another improvement we did to enable saving edits for a polygon while it's vertices are being edited . We will try to fix this in future release.
Preeti
