Updating a feature in a feature layer
1974
04-21-2014 06:32 AM
NickBrueggemann
I'm sure this is a simple thing I just can't figure it out...  How do I update the location of a feature in a feature layer?  I can add a feature and remove a feature.  How do I update an existing one?  Thanks for the help!
- Nick
AnttiKajanus1
Depending your editing needs, you have different approaches.
I recommend you to check there links:
To see samples how to work with graphics (GraphicLayers) / features (FeatureLayers) see Sample app (this is packaged in installer so if you have installed full SDK you should have it) and sections Mapping \ Graphics Layers and Editing.
Hope that these will help. Let me know if you have more questions.
NickBrueggemann
Thanks for the response!
I'm familiar with using the editor widget to add, update, and delete features.  I'm trying to accomplish the same behavior as the editor widget but I'm wanting to do it myself programatically.
- Nick
AnttiKajanus1
Are you working with GraphicLayers or FeatureLayers and are you also going to save them to the FeatureService?
If you are working with MapPoints, then use MoveTo()-method to change the location. See MoveTo sample from DevSummit demos or Sample App \ Mapping \ Graphics Layers \ Moving graphic objects as reference.
