Shapefile Labels - or how to access the shapefile attribute database
5014
07-23-2014 01:26 AM
LeeColclough
I'm loading various shapefiles using ArcGIS for WPF and displaying them on a map (the mechanism for doing this is taken from the ArcGIS WPF runtime examples - see http://www.arcgis.com/home/item.html?id=953a530ada30477d95cc69e788268bc9).
I have a shapefile that contains Point information, and contained in it's attributes are the text labels that apply to those points. I cannot see how to access that information. I know the DBF file is being used as if I delete that file the shapefile will not render as it has no symbol information. Despite this, I cannot see when debugging the provided example how to access this information.
Obviously I could simply open the .dbf file manually but that seems awfully clunky. Does anyone have any help or pointers for me?
Many thanks in advance.
Lee.
nakulmanocha
If you use ArcGIS Runtime for .NET which supersedes WPF API. Then you can add and query a shapefile to get its attributes. I don't think its possible with ArcGIS Runtime for WPF.
