Service Error, code: 400, message: Unable to complete operation., detials: Error executing tool.: Traceback (most recent call last): File "C:\users\sau\LO~SSGOF\ArcGISRuntime\Documents\ArcGIS\Packages\CreateGDB_27EDBABC-57B4-4465-A41C-325357C44437\v103
3702
09-22-2015 09:48 PM
MrudulaCh
File "C:\users\sau\LO~SSGOF\ArcGISRuntime\Documents\ArcGIS\Packages\CreateGDB_27EDBABC-57B4-4465-A41C-325357C44437\v103\mrudula\CreateGDB.py", line 7, in <module>
arcpy.CreateFileGDB_management(out_gdb_path,gdb_Name)
File "c:\program files (x86)\arcgis\desktop10.2\arcpy\arcpy\management.py", line 15674, in CreateFileGDB ExecuteError: Failed to execute. Parameters are not valid. ERROR 000732: File GDB Location: Dataset G:\ArcGIS\Mrudula does not exist or is not supported Failed to execute (CreateFileGDB).   Failed to execute (CreateGDB). Failed to execute (CreateGDB)."
MrudulaCh
The above error is coming while using .gpk File in QtRuntime
.Gpk file was created in arcMap
MichaelBranscomb
Esri Frequent Contributor
Please can you include the relevant section of python code from the script and your code which executes the Geoprocessor task?
I suspect it's a path issue, your script is either trying to read or write to "G:\ArcGIS\Mrudula" - does that exist? Is it hardcoded in the script?
Cheers
Mike
