S57 display
6634
11
01-20-2013 08:40 PM
ModyBuchbinder
Hi all
I am trying to display a S57 file in the new RunTime WPF SDK 10.1.1
The example for HydrographicS57Layer is clear and works fine.
Now I would like to control my display properties (for example NIGHT color scheme).
As far as I understand I need the HydrographicS52DisplayProperties class for this.
I cannot find the way to get HydrographicS52DisplayProperties from HydrographicS57Layer.
The HydrographicS57Layer is written in the HydrographicS52DisplayProperties help (see here:    http://resources.arcgis.com/en/help/runtime-wpf/apiref/ESRI.ArcGIS.Client~ESRI.ArcGIS.Client.Advance... ).
Mody
EugenReiswich
Hi Antti,
that was a very good hint, thanks a lot!
I'm able to load my data into the example. When I check and uncheck the soundings checkbox the soundings appear and disappear from the map. However, when I try to disable soundings programmatically at start up, they just don't disappear. This is how I disable soundings:
public S57DisplayPropertiesSample()
            InitializeComponent();
            // Create default instance of display properties and set that to DataContext for binding
            DataContext = HydrographicS52DisplayProperties.Default;
            HydrographicS52DisplayProperties.Default.ViewGroupProperties.Soundings = false;
            ZoomToHydrographicLayers();
Is this a matter of timing or something else?
EugenReiswich
Hi Antti,
I could sort this problem out myself. It was really a matter of timing. I had to change the display properties after all Layers were loaded:
        // Zoom to combined extent of the group layer that contains all hydrographic layers
        private async void ZoomToHydrographicLayers()
            try
                // wait until all layers are loaded
                await MyMapView.LayersLoadedAsync();
Thanks for your help again!
