Removing buffering circle graphics in a WP7
1269
01-09-2014 09:37 AM
Kai_LunGoh
I have tried a lot of method but just can't remove the graphics of the circle drawn. Can someone help me with this ?
GraphicsLayer graphicsLayerHeat = map.Layers["Layer5_buffer"] as GraphicsLayer;
                foreach (var graphic in buffersList)
                    //graphicsLayer.Graphics.Remove(graphic);
                    graphicsLayerHeat.Graphics.Remove(graphic);
The above code is used for drawing a circle, I can't remove the graphics that is drawn on this layer. Help pls.
I have tried this but it wont work.
 graphicsLayer = map.Layers["Layer5_buffer"] as GraphicsLayer;
            graphicsLayer.ClearGraphics();
The code to draw the buffer is here:
public void drawBuffer(double radius, int pointCount, MapPoint currentPoint, GraphicsLayer gl)
            //bufferLayer.removeAll();
            MapPoint point = currentPoint;
            ESRI.ArcGIS.Client.Geometry.Polyline pl = new ESRI.ArcGIS.Client.Geometry.Polyline();
            ESRI.ArcGIS.Client.Geometry.Polygon polygon = new ESRI.ArcGIS.Client.Geometry.Polygon();
            ESRI.ArcGIS.Client.Geometry.PointCollection routePoint = new ESRI.ArcGIS.Client.Geometry.PointCollection();
            for (int i = 1; i <= pointCount; i++)
                double x;
                double y;
                x = (point.X + radius * Math.Cos(2 * Math.PI / pointCount * i));
                y = (point.Y + radius * Math.Sin(2 * Math.PI / pointCount * i));
                routePoint.Add(new MapPoint(x, y));
            routePoint.Add(routePoint[0]);
            polygon.Rings.Add(routePoint);
            GraphicsLayer mygraphicslayer = gl;
            //mygraphicslayer.ClearGraphics();
            Graphic graphic = new Graphic()
                Geometry = polygon,
                Symbol = Heat
            buffersList.Add(graphic);
            mygraphicslayer.Graphics.Add(graphic);
BKuiper
From your code it is not clear that "Layer5_buffer" is the actual graphics layer to which the graphics are being added.
Make sure that the GraphicsLayer ID to which the graphics are added matched the string in the following line
