Porting from MAPPOINT to ESRI WPF
1053
12-21-2011 04:47 AM
MIKEMENDEL
Hello
I would like to know if someone made Porting from MAPPOINT to ESRI WPF .
Regards,
  Michael Mendel
BKuiper
Hi Michael,
i never worked with Mappoint, but i just wanted to point you to MapIt (http://www.esri.com/software/mapit/index.html). You probably know this application, but just wanted to make sure.
Hopefully somebody else can help you a bit more on your question. Perhaps you can also tell a bit more on what you are trying to achieve. Which dataformats, etc.
MIKEMENDEL
Hello
I try to port the MAPPOINT API's to ESRI API's.
MichaelBranscomb
Esri Frequent Contributor
If you're porting your application from MapPoint to ArcGIS you might be interested in one of several ESRI .NET SDKs:
Desktop WPF applications: http://resourcesbeta.arcgis.com/en/help/runtime-wpf/concepts/index.html#//017000000031000000
Web SilverLight applications: http://resourcesbeta.arcgis.com/en/webapis/silverlight-api/community/
Windows Phone: http://resourcesbeta.arcgis.com/en/help/windows-phone/sdk/concepts/index.html#//011v00000004000000
For serving up your spatial data from your backend database (assumed to be SQL server) you'll also be interested in ArcGIS Server (http://resourcesbeta.arcgis.com/en/help/main/10.1/index.html#/What_is_ArcGIS_for_Server/01540000037p...). There is also a lightweight Spatial Data Server for SQL Server included with "ArcGIS for Server Basic 10.1": http://resourcesbeta.arcgis.com/en/help/main/10.1/index.html#/What_is_ArcGIS_Spatial_Data_Server/01s....
Cheers
Mike
