Performance, measuring fps?
1350
05-24-2012 02:47 AM
AlexanderMagnusson
Hello
I would like to do some performance measurement, one such measurement would be the achieved fps. However I have not identified any obvious way to do this. (Of course I could always try staring at the screen and count the updates, heh).
If anyone has any ideas on how to measure the fps I'd be really happy to hear.:)
AlexanderMagnusson
I'm not really sure but perhaps a Drawobject could be used somehow? Maybe I've misunderstood what a Draw object is meant to do but it seems it's supposed to enable a user to draw graphics onscreen. In that case I don't think it's usable.
MichaelBranscomb
Esri Frequent Contributor
You didn't say exactly what aspect of performance you would like to measure but you might be able to use the WPF perforator (http://msdn.microsoft.com/en-us/library/aa969767.aspx). Note that the map would be on a different rate to you application window because it's rendered in a background thread to avoid holding up the UI.
Cheers
Mike
AlexanderMagnusson
Hello Mike
What I would like to measure is the FPS of the Map. The reason is to determine how well it can handle a lot of displayed graphics and whatnot. It would be good then to get a somewhat accurate measurement.
