Mpk And Gpk File Extracting Problem
3344
03-06-2012 03:35 AM
GirayCoşan
I have a problem about mpk and gpk file.when  running programs, extracting the package GPK or MPK under the folder of Arcgis/Packages.Each program is run, it is again and it has name in order for  example  gpk file :routing1,routing2......routing10...
How can I solve this problem?
Thanks...
MichaelBranscomb
Esri Frequent Contributor
We've improved the package unpacking behaviour since Beta 2 so you should no longer see this in Pre-release - but please retest and let us know. You should only see this if the source MPK/GPK has changed and the package needs to be unpacked again (the package is inspected to check the  packaging timestamp).
Cheers
Mike
