Missing reference or assembly
4203
07-10-2013 02:36 AM
PremaRajanna
I am working on WPF application using Visual Studio 2010. I have just started learning this app. When I am creating map I am getting below error but I added all the reference files from ESRI resources.
The type 'esri:Map' was not found. Verify that you are not missing an assembly reference and that all referenced assemblies have been built.
Prema
MichaelBranscomb
Esri Frequent Contributor
It sounds like you might be missing the XAML namespace? - make sure your XAML contains an esri namespace reference e.g.
<Window x:Class="ArcGISWPFSDK.Map"
    xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
    xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
    xmlns:esri="http://schemas.esri.com/arcgis/client/2009">
    <Grid x:Name="LayoutRoot" >
        <Grid.Resources>
            <BooleanToVisibilityConverter x:Key="BooleanToVisibilityConverter"/>
        </Grid.Resources>
        <esri:Map x:Name="MyMap" UseAcceleratedDisplay="True" WrapAround="True" Background="#FFE3E3E3">
            <esri:ArcGISTiledMapServiceLayer ID="MyLayer"
                Url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer" />
        </esri:Map>
        <ProgressBar x:Name="MyProgressBar" IsIndeterminate="True" VerticalAlignment="Bottom" Width="200" Height="20" Margin="10" Visibility="{Binding Path=IsBusy, Converter={StaticResource BooleanToVisibilityConverter}}"></ProgressBar>
    </Grid>
</Window>
Cheers
Mike
