Missing ESRI.ArcGIS.Client.Local
5227
01-30-2013 03:31 PM
DanielSelnick
I just downloaded the SDK. There is no ESRI.ArcGIS.Client.Local namespace or .dll
After reading through the documentation and forums, this is a needed component for using local data.
I also realized that SDK 1.0 contains Local, while 2.3 and 2.4 do not contain Local.
Should I just use 1.0 or am I missing something?
MichaelBranscomb
Esri Frequent Contributor
Unfortunately you've downloaded the old ArcGIS API for WPF (v2.4). Back in July we rolled this into a larger product with support for local data called the ArcGIS Runtime SDK for WPF. That was the v1.0 release of the SDK, although it included v3.0 of the client dlls. In January we released the second version of this SDK, with everything now labelled v10.1.1 to indicate commonality with the rest of the ArcGIS system.
To download the latest SDK you'll need an Esri Developer Network (EDN) subscription which you can then use to sign into the customer care portal and download the software along with dev/test licenses.
EDN info: http://edn.esri.com/
Software download: http://customers.esri.com/
Cheers
Mike
MichaelBranscomb
If you open Windows Explorer and browse to the client dll folder (C:\Program Files (x86)\ArcGIS SDKs\WPF10.1.1\sdk\bin) is there an ESRI.ArcGIS.Client.Local.dll in that folder?
If not that sounds quite unusual - I'd suggest running a repair of the setup.
Cheers
Mike
DanielSelnick
This is running just the SDK installer, with nothing else installed.
Running the SDK installer, the binaries are installed on to C:\Program Files (x86)\ESRI SDKs\WPF\v2.4\DotNet40
I've ran the SDK installer on two different machines, and Client.Local isn't included on both machines.
MichaelBranscomb
Cheers
Mike
DanielSelnick
Yup, I downloaded the SDK from
http://help.arcgis.com/en/webapi/wpf/index.html
Thank you for the help!
