How do I check if an Url string is valid as a layer?
3110
7
08-04-2011 12:39 AM
linusang
Given a arbitrary url string.. how do i know if the url is connected successfully and valid to be added to a map?
RichardWatson
I am not sure that I understand your question.
When you publish a map service there is a URL for each layer.  The way the URL is generated is very deterministic and it includes several elements including the layer indice which is simply the 0 based index of the layer in the map.
linusang
i'm providing a way to allow users to enter any url and add to the map dynamically... i would like to know if the url the user entered is connected(server exists, connection exists,  internet connection available), is a valid ArcGIS Server layer, or a KML layer, or a WMS layer, etc.
i would like to verify the url before adding to the Map...
like a web browser.... when you type http://www.yahoo.com.. it is a valid link.. however it is not a valid ArcGIS Map layer......
RichardWatson
I think that you just have to call a REST method on that URL to confirm whether or not it is valid.  Look through all the methods available and pick one that makes sense.
linusang
do you have any links of information or source code that demonstrates that functionality?
RichardWatson
http://resources.arcgis.com/ is the place to start.
linusang
Hi, I'm using the HttpWebRequest class to check...
however, how do i know if the HttpWebResponse is a valid ArcGIS Server response?
RichardWatson
Send a request that asks for a response in JSON and see if you get back something valid.
If you don't understand this then play with it using the services directory.
